Posted by Janicholson on February 05, 2014 at 18:23:36 from (74.60.94.18):
In Reply to: Belly pum posted by Zeke5738 on February 05, 2014 at 17:12:21:
If there is pressure on it the lever can (because of wear) get stuck (usually in the hold position. Lift the blade and see if there is enough reduction in internal pressure to allow it to push in. (holding up the blade with real cribbing that will not tip, and loosening a hose carefully might allow it to lower. Vent plugs are needed to allow the cylinders to breathe. If there is pressure in the lines, be very careful bleeding it off. Never with the implement free hanging in air. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
