Farmall 460 gas power
Posted by Tractordanp on February 06, 2014 at 17:25:40 from (50.137.83.148):
I did some wheeling and dealing this week and came home with a farmall 460 gas has wide front end it looks like at some point it was gonna be restored new harness looks like new gaskets which I was told fresh engine
It starts real easy even at 2 degrees this morning and it was -10 the day I went to check it out engine didn't even make a full revolution and it was running
No smoke don't burn any oil runs real smooth but when I took it for a ride around home the hill leading up here is pretty steep I had to use ta to make it up some of the hill my 460 utility diesel walks right up on the high side without much trouble my 560 diesel done not even act like there is a hill now my 560 has loaded 15.5x38 with 3 sets of wheel weights my 460 utility has loaded 14.9x28 with one set of weights and the 460 gas in question had 13.6x38 none loaded and no weights so it's pretty light compared to the other two
Is this right is the 460 gas got that much less power than the diesel? Or am I missing something?
Thanks dan
