Re: Farmall H interference engine?
Posted by Nebraska Kirk on February 06, 2014 at 18:28:25 from (207.91.4.159):
In Reply to: Farmall H interference engine? posted by Dean Wheeler on February 06, 2014 at 18:21:51:
I think your problem is the starter is stuck in the engaged position, that can happen with a bad spot on the ring gear. Unbolt the starter to get it unstuck or try rocking the tractor back and forth in 5th gear to see if that will pop it loose.
