Farmall H interference engine?
Posted by Dean Wheeler on February 06, 2014 at 18:21:51 from (24.236.255.110):
Are the engines in Farmall H's interference engines (valves/pistons can hit if timing is off)? Or is that even possible on these engines?
Mine was rolling over, but wouldn't start tonight. After trying to start it a couple times (I have a bad spot in the flywheel, so went to the front of the tractor to move the engine slightly with the hand crank, but when I try to crank by hand, it's hung up tight.) Haven't hit starter again, thinking that could be bad. Pulled all 4 spark plugs and still won't budge.
Ideas?
