hi, I had an air compressor with a IH engine. I used to rent it out for people to blow irrigation lines in the fall. The starter switch stuck in start position and the fellow didn't notice (I don't know how) and it just chewed the ring gear and bendix gear to rat@#$ so I had to replace everything. Big work!!!. When I noticed the switch stuck, I took it out and found a little hole for lub. It seems ok but I replaced it anyway. Just some memory. Ed Will
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
