Re: Zenith Carb Help Needed
Posted by old on February 10, 2014 at 20:46:19 from (209.86.226.56):
In Reply to: Re: Zenith Carb Help Needed posted by labman98 on February 10, 2014 at 18:40:07:
The pressure you put on that needle is a whole lot more then the float will put on it so still good chance you need to put a set in the end of that rubber tipped needle
