Re: Zenith Carb Help Needed
Posted by labman98 on February 10, 2014 at 18:40:07 from (208.81.196.42):
In Reply to: Re: Zenith Carb Help Needed posted by old on February 10, 2014 at 18:26:58:
Ok. What haven't I done it seems like :) I replaced the needle and seat with new. I had put the needle in the seat and held up gently with my finger while turning on the gas and it held it back fine. I thought it may be leaking by the seat gasket but was good there too.
I filled the carb bowl up with gas and let sit, no leaks then but I can start to see it coming up the idle jet if I put to much in.
I was thinking the float may be too heavy BUT once I loosen the 4 screws a bit it seems to want to work. So I'm sort of thinking something is binding but not sure what could be. Any help is appreciated!
