Re: 574 range lever
Posted by jiminy on February 16, 2014 at 05:14:16 from (209.105.143.169):
In Reply to: 574 range lever posted by Brass Ring on February 15, 2014 at 21:59:48:
You have to do from the top..remove fuel tank, seat, tin that seat is mounted to and hyd lines etc...Then remove top cover of tranny. Its heavy so a hoist is needed. A five minute job once you get all the stuff out of the way..Just had to do the same thing to a 674...part was around 80 bucks
