574 range lever
Posted by Brass Ring on February 15, 2014 at 21:59:48 from (184.71.97.206):
have 1968 IHC 574 with range shifter shaft broken off in tranny wall. stuck in reverse. what is best way to access and remove to replace broken shaft?
