Here is a simple test to tell if your points are working. Attach a test light to the primary terminal of the distributor and the other end to ground on the tractor frame someplace. With the ignition switch on the light will glow if the points are open. If the points are closed you will not see any light. Now crank the engine the light should blink at you because the points are opening and closing.
Now, lets do a little troubleshooting. 1. If the points are open and no light, you are not getting power from the switch through the coil to the points.
2. If the light glows and does not blink/flash while cranking your points are not closing letting power go to ground charging the coil.
Post back with your findings and I'll help you. Charlie U
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
