Posted by JimB2 on February 16, 2014 at 10:00:53 from (99.240.243.222):
In Reply to: 574 range lever posted by Brass Ring on February 15, 2014 at 21:59:48:
Hi Brass Ring,
From archives: Broken Shifter Lever:
Hi Irving, I have changed many of those parts, at the Case-IH dealer, where I have worked for. You can remove the lever and replace it by the left side of the rear transmission. Just drain the oil, remove the MCV control valve ( the plate that hold the hydraulic pump and filter) With a short 7/8 open wrench, loosen the sealed nut, remove the broken shaft and replace with the new one. It has a big spline for the timing. Just align the short lever with the fork. Bernard le mécano Québec Canada
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
