Exhaust Pipe Removal Example
Posted by eastsider on February 16, 2014 at 13:25:28 from (24.111.75.41):
Since I see a lot of questions over the years about how to remove the old, rotten exhaust pipe from the manifolds, I thought I would share the procedure I always use. I am restoring my H right now, and had to refurbish the manifold recently.
Step one...carefully use a Sawzall to cut through the old pipe...this can be done either on or off the tractor. This one happened to be off.
third party image
third party image
Step two: Make a couple of careful cuts into the threaded area with the sawzall again, being careful not to cut into the manifold if possible. Once done, chisel out the small chunk and the rest will peel right out.
third party image
third party image
third party image
Step 3: Wire wheel, bead blast and scrape, scrub etc... Make sure to clean out the drain holes on the bottom. They are more than likely plugged up! See the difference? Then clean out the threads...use a pipe tap if you have one, or a dremel tool works well too.
third party image
third party image
third party image
Clean it inside and out, I use brake cleaner! Blow it clean so all the glass beads are gone, and reinstall. I don't know what the markings here mean...did I really find an M&W replacement manifold, or are these casting letters from IH?? There was an IH part number on it too. Any thoughts??
third party image
third party image
third party image
I hope you can use this for your restoration someday!
Mark
