Re: Exhaust Pipe Removal Example
Posted by jdleach on February 16, 2014 at 18:24:34 from (98.212.87.58):
In Reply to: Exhaust Pipe Removal Example posted by eastsider on February 16, 2014 at 13:25:28:
Good write-up for those who have to face such a chore. The big trick is to make sure you do not get into the threads. That said, even if you do, there will not be enough damage to affect the function and fit.
Agree with leaving a little more of the pipe. Give some material to chisel and whack on.
And thank you for the part about drain holes. After some 40 years of being around H's, I did not know they were there. Then again, I haven't tore one down before till this January.
