Re: Super A Starting Problems
Posted by djhammerd on February 19, 2014 at 18:58:25 from (173.66.69.90):
In Reply to: Super A Starting Problems posted by C. Amick on February 19, 2014 at 18:14:27:
I have drained the bowl of the carb from the petcock on the underside of the carb, so I know gas is in there. And yes, I did have gas dripping one time.
If I don't get it started before Sunday, I may be able to pull it. The snow has to melt here first... before I can move the tractor to where I can pull it, I don't want to mess up my yard.
Using a 12 volt source for a starting test (without the generator/regulator involved again) has crossed my mind. I was just hoping to get it running using the six volt system.
I am considering changing over to a 12 volt system, but if the 6 volt system works well, I may not convert.
It's my understanding that I'd need to install a ballast resister between the battery and the coil (to protect the coil) if I test with a 12 volt battery.
Is there any reason I'd need to change to a negative ground for the test?
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
