Re: Super A Starting Problems
Posted by C. Amick on February 20, 2014 at 09:26:49 from (50.242.45.59):
In Reply to: Re: Super A Starting Problems posted by djhammerd on February 19, 2014 at 18:58:25:
I"m not advocating that you should convert it to a 12 volt system. Most of my tractors are still 6 volt and work fine. Just make sure you have the larger battery cables for the 6 volt system. I think the minimum cable size is #1. You can still jump start it from a 12 volt system without damage to the 6 volt system, if you hook the jumper cables at the starter. Hook one to the starter post and the other to the tractor body. No, you don"t have to change to a negative ground. Just make sure the switch is on. :)
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
