Re: Super H bottom pto shaft replacement
Posted by Dave S. on February 22, 2014 at 07:53:45 from (208.92.171.156):
In Reply to: Super H bottom pto shaft replacement posted by Deerepower on February 22, 2014 at 07:17:12:
If you are wanting to remove the transmission counter shaft you have to remove the transmission driving shaft(input shaft) and the main shaft(one with sliding gears) first. Then remove counter shaft nut, bearing retainer, and front bearing.
Next remove counter shaft rear bearing snap ring(you can drive the shaft and bearing back to help gain access to snap ring), remove bearing and lift out counter shaft.
If you are only needing to access the pto shaft take the five 3/8" bolts out and pull it out the back of transmission.
