Super H bottom pto shaft replacement
Posted by Deerepower on February 22, 2014 at 07:17:12 from (216.170.10.41):
I am wanting to replace the bottom pto shaft on my super h. Removed the top cover and removed the back engagement shaft. (bottom pto shaft badly damaged ran a 10inch auger to much) I then removed the belly pan and removed the nut that holds the shaft I can drive it a little then it stops. I am stumped and what to do next. I don't need to removed the top shaft do I? or is there any better way to do this thank you for any help
