Re: Play in rod bearings on 3 and 4
Posted by pete 23 on February 22, 2014 at 15:03:23 from (74.33.90.72):
In Reply to: Play in rod bearings on 3 and 4 posted by CrvnJ on February 21, 2014 at 12:45:19:
Just to add a little more to the discussion of shims. Perfect Circle offered and pushed pretty hard the use of a tapered shim between bearing insert and rod cap back in the 60's. Their reasoning was a undersize bearing not being available to compensate for some small amount of wear on crank journals. I never used them though.
