Re: Play in rod bearings on 3 and 4
Posted by Duner Wi on February 22, 2014 at 16:41:55 from (216.226.80.242):
In Reply to: Re: Play in rod bearings on 3 and 4 posted by pete 23 on February 22, 2014 at 15:03:23:
I think you can still get tapered shims.
http://deckwartaperedshims.com/main-bearing-shim-installation.php
I use them my junk for over 40 years with out problems. For me they are a bit time consuming
to fit. I have never used deckwar shims as I still have new old stock from back when.
