Re: 1949 Farmall M
Posted by Zachary Hoyt on February 26, 2014 at 04:54:21 from (184.12.76.163):
In Reply to: Re: 1949 Farmall M posted by mcgyver44 on February 25, 2014 at 19:43:39:
I would look up through where the belly pump was and see if the
input shaft is turning when the engine is running. If not I would
look to see if the flywheel is turning, if it is the the problem is in the
clutch. If the input shaft is turning then your problem must be
between it and the upper constant mesh gear. I don't know
specifically but I think once you look up in there it will be apparent.
The PTO running the hydraulics doesn't really signify either way
since the PTO is also powered by the countershaft just like the belly
pump.
Zach
