Slater.... You may well be right, at least with regards to the model of tractor (if it was a tractor) the motor came from. I just looked at pictures of radiator replacements (as well as pictures of used radiators on eBay. The 140 radiator is the closest match for size and hose configuration for the radiator that is on the tractor now.
I'm saying this because it appears the original Super A radiator had an outlet on the top (going to the engine) that pointed down at an angle toward the engine. The A, B, C and Super C also had the upper hose outlet pointed down toward the engine.
The radiator on my tractor today has a straight out outlet (90 degrees from the radiator) similar to the 140.
Also, if anyone can confirm that the serial numbers on your document represent both the engine serial number as well as the overall tractor serial number (assumed), it would pretty much nail it.
Could someone that has a 140 (preferably 1959, but others also) look at the overall tractor serial number and compare it to the engine serial number (under cyl one), then post whether they are the same or different?
This post was edited by djhammerd at 20:49:28 02/26/14 6 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
