Re: IH 706 Gas - Reputation
Posted by The tractor vet on February 28, 2014 at 08:03:35 from (75.19.125.103):
In Reply to: Re: IH 706 Gas - Reputation posted by mkirsch on February 28, 2014 at 06:57:20:
If you have to dance with the clutch pedal then you are out of adjustment on the clutch set up Adjustments . None of or 06 series shift hard , just push the clutch pedal down and two fingers will get the job done , no jerking tugging cussing swearing they just slide to what ever gear you want . It is when they get out of adjustment is when you start making things wear out . And i do not need that socalled expensive kit to make them shift smooth.
