Posted by Janicholson on February 28, 2014 at 18:12:24 from (74.60.94.18):
In Reply to: wd9 problems posted by m-mjohn on February 28, 2014 at 18:06:21:
Are you waiting for 2 minutes run time when the temp is in the 40s or 5 minutes when the temps are near freezing and more if needed. If you are, then the compression relief valve rack may be stuck. The third valve in the head must close to allow diesel compression. If stuck open, they will not run on diesel. It might need to have the valve cover pulled to check the third valve operation, If stuck, there will be no external indication. Let us know. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
