Re: wd9 problems
Posted by rustred on February 28, 2014 at 18:33:25 from (74.214.152.80):
In Reply to: Re: wd9 problems posted by Janicholson on February 28, 2014 at 18:12:24:
will add also, that it is very easy to tell diesel compression from the gas.
turn it over with the starter on the diesel side and you will know as the engine will crank slow due to extra compression.
and also when operating the compression lever you will hear it "snap" from one to the other.
also if that little 20.00 spring is broken in the shift over mechanism it will stay on the gas side and not switch to diesel. it is right behind the carburetor.
