Posted by Hendrik on March 05, 2014 at 04:39:26 from (193.30.192.187):
In Reply to: Re: Farmall A Lo-boy posted by Farmall A Tractor on March 04, 2014 at 13:05:36:
QUOTE: ...but there is quite a bit of meat there.
If you swing the final drives forward (so that the wheelbase is shortened) the area of the final drive casting where you will likely be removing some of that "meat" to accommodate the brake system will be under compressive stress. The compressive strength of cast iron is much higher than its tensile strength, so I think you may safely remove some material. Good luck. In my youth there were three brothers using their Super A in their orchard. (Must have been around 1960.) That Super A was also modified to ride low by rotating the finals. Don't have any pics; neither do I remember how the brakes were rigged. Hendrik, from The Netherlands
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
