Re: NEED IHC 284 PART
Posted by BillOHIO on March 11, 2014 at 07:36:05 from (68.73.97.109):
In Reply to: Re: NEED IHC 284 PART posted by Bob Evans on March 11, 2014 at 06:30:04:
Bob, First lets make sure I am looking up correct part for you.
Go to www.messicks.com; enter 284 and then search ;3 choices will comeup , choose 284 International Tractor ;click 07, Hydraulics ;click on 10-18 Hyd Pump Drive.
Then you should see coupling and drive illustration. Item 17 shaft is one item I think you need. New number, item 17.1 is 1002780C4 $443.39. Another choice for item 17.1 is 7430177R2 $137.33, for tractor w/power steering.
Item 21 is coupling 1002779C3 $206.36
So if those are items you need, pricey, but when I run into this I am at least glad they are still available.
Finding these parts used would be similar to hunting for hen's teeth ☺ If I have looked at correct parts let me know and I do have a couple contacts that I will gladly check for used.
I am puzzled that it only lists Gas engine in choice of Hyd Pump Drive.? I would guess if gas or diesel these parts would be the same ?
Bill
