Re: battery drains continue on M
Posted by dick on December 19, 2000 at 15:25:46 from (199.239.12.58):
In Reply to: battery drains continue on M posted by joe on December 19, 2000 at 14:58:12:
Sounds as if you have a short to ground somewhere. If you have a test meter, disconnect the non-grounded terminal from the battery, and check the resistance between the disconnected terminal and ground (the frame of the tractor or the grounded terminal of the battery) with the ignition off. Should over-range the meter, which would blow my short-to-ground theory - in this case make sure you have a good ground contact for your meter. If the meter doesn't over-range, you probably have a bad ignition switch, but the problem might be at the starter solenoid or switch (depending on which you have on your M). Try disconnecting one or other of the wires branching out downstream of the non-grounded terminal and check the disconnected wire's resistance to ground. If it over-ranges the meter, the problem is in another branch. Keep poking around and you should be able to localize the problem. Good luck, hope this helps.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
