a '64 when new would have had the RD pump. has it been changed to the roosa master?
it sounds like you've got other issues here, but i thought i'd share one of my experiences- on a tractor with RD pump- would run fine at low to mid speeds, at the high end would develop a miss. turns out there is a spring in the pump that forces the plungers to "return" to take a charge of fuel for each pulse. with that spring broken the plungers wouldn't return fast enough at high speeds.
so you might get lucky and have a good one with a change of oil and O/H pump.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
