806 miss and smoke…alot of smoke
Posted by Andrew Psencik on March 11, 2014 at 15:29:44 from (184.63.210.182):
I just purchased a 1964 806d. I bought it with the understanding
that it had a miss and smoked white pretty bad. (smoke reeks of
diesel smell). I went ahead and bought the tractor thinking it would
be an easy injector swap. Tractor starts easy in cold weather (35+),
runs smooth at idle, has very little blowby. When revved up, it has
an awful miss. I cracked all of the injector lines and got a change in
pitch off all injectors, but smoke and miss never cleared up. Has
about 10 psi oil pressure at idle and as much as 40-50 at pto
speed. The inj lines were pretty frozen to the flare nut so i did not
crack them much, just enough to get a dribble of fuel and hear a
change in engine performance. Any help would be greatly
appreciated. Thanks. AP.
