Should have the same pressure on both if the settings are reversed. Just thought the side port is what you were using for pressure. Early units only made about 500 PSI. Later it was raised to around 750 to 850 PSI depending on the pump condition. Pressures may be to low for use with a small cylinder lifting a load made for tractors with more PSI.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
