I got no detectable pressure when hooked to either remote line from the 2 way valve
I then tried the gauge on the left front pressure elbow with no noticeable reading on the gauge
After that I disconnected the right hand pressure port, which has the line supplying the 2 way valve. I stuck the gauge there and got a detectable Amount of pressure, but was unable to tell the correct psi, although I believe it was under 300psi if my gauge is right.
Need another lower psi gauge to determine this.
If I have good pressue from lift all ports, my valve is leaking or faulty
If I have low pressure from lift all ports my problem lies within the belly pump.....
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
