Re: 806 miss and smoke…alot of smoke
Posted by Al Baker (pumpman) on March 12, 2014 at 08:22:48 from (96.42.135.158):
In Reply to: 806 miss and smoke…alot of smoke posted by Andrew Psencik on March 11, 2014 at 15:29:44:
It is very common to see a engine start fine and run fair at low speeds. If the smoke and miss come on at about 1200 RPMs and get worse the higher you go that is almost always a advance issue. A stuck nozzle will act simular, but will smoke bad at all RPMs (white smoke) Fuel in your oil is from the drive seals. If someone has replaced the old RD pump with a Roosa you are going to be ok. Good pump shop will get 350-400 bucks to fix you up. If you have the old RD you might be let down. Not sure who still has parts for them. Call around, don be afraid of price shopping. If no one wants to give you a fair price in your area give me a call. I have been through many hundreds of Roosa pumps. Good luck,,, Al 231/757/0064
