Re: new GENERATOR and still no luck HELP!!!!!
Posted by kbarry on March 12, 2014 at 16:25:56 from (207.119.217.215):
In Reply to: Re: new GENERATOR and still no luck HELP!!!!! posted by Hugh McKinney on March 11, 2014 at 19:27:14:
I hooked it the same exct way I took it off beside the block that has a positive and negative. however I tried re grounding my coil and starting it today an wires on the ignition were starting to smoke I am not an expert but do not think this is good. if it were a positive ground will I mess it up if wired backwards....and im not changing the polarity by jumping wires from BAT to GEN I think that is why I messed my GEN up in the first place
