I will check the numbers and letters on the base flange. Yes, the 25L plate is not any good. So I used the hole pattern on the 25L plate to drill another set of holes in the 8R plate. I think this will work? There wasn"t much that I could use on the distributor that I bought. The splines on both the gears were stripped in addition to the 25L plate being bad. The mounting holes in the cams from the 25L distrubutor are also badly worn, but I think they are usable.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
