Re: Which Distributor is Correct in These Photos
Posted by D Slater on March 13, 2014 at 06:26:32 from (184.14.199.60):
In Reply to: Which Distributor is Correct in These Photos posted by C. Amick on March 13, 2014 at 05:42:30:
Yes I have drilled the # eights to use on a gas before when I needed a different advance and also a good rotor shaft or also a housing with serviceable bushing. That way you can make the hole to the max advanced wanted. Placement of the hole is critical on placing the weights on the right swing arc to the cam. Will also change the advance rate from original with little changes.
Think I didn't say the first letter on the base can ID the original advance and intended use. May not be what's found now though. First letter was called the distributor symbol.
Interestingly the list I have that id's a N symbol gasoline says its a CW distributor. Doesn't specify the direction viewing from.
400,450 parts book doesn't specify the rotation direction. Older parts books for like A or C say CCW for a distributor turning the same direction as a 400 gas.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
