Re: melted gounds on IH 460 GAS MOTOR HELP!!!
Posted by Janicholson on March 15, 2014 at 07:51:05 from (74.60.94.18):
In Reply to: Re: melted gounds on IH 460 GAS MOTOR HELP!!! posted by kbarry on March 15, 2014 at 07:16:51:
There are no resistors in coils. The common (incorrect) thinking is that if some coils have resistors in the circuits leading to them, that those indicating they don"t need an external resistor have one inside. The internal coils are just wound with more and thinner wire to handle higher voltage at the same current levels.
If your coil says it does not need and external resistor do not use one. However!! the reason the original wiring diagram has a resistor in it, and the reason it is important is that the ignition bypass circuit (from starter solenoid to the coil side of the resistor) is used to provide cranking voltage to the coil while the engine is being started. This bypass increases the voltage at the "resistor required" coil, putting hot spark to the plugs. If a coil with no resistor required is used, that wire does nothing and the 12volt coil is operating on the 10 volts available when the engine is being cranked. This produces less spark and sometimes no start.
Jim
