Re: Re: stuck in gear
Posted by Wardner on December 19, 2000 at 22:03:07 from (63.23.215.180):
In Reply to: Re: stuck in gear posted by Farmer Bob on December 19, 2000 at 21:29:22:
Sounds like a PO was messing around with the lever before he sold the tractor to you. There should not be a nut and bolt in there. On each side of the outside of the tower there should be a 1/2 (?) inch flat freeze plug. They retain an inner and outer shaft that the shift lever swivels on. My recollection is that they come out easily with a drift after you destroy one of the plugs. I am concerned that maybe the PO welded or brazed something (the bolt maybe) and it cannot be moved. Remove the bell shaped shield and get a good look.
Post A Followup
: Re: Re: Re: stuck in gear
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
