Re: W-9 Magneto with 12 volt custom conversion is...
Posted by Janicholson on March 19, 2014 at 18:43:17 from (74.60.94.18):
In Reply to: Re: W-9 Magneto with 12 volt custom conversion is... posted by zim on March 19, 2014 at 17:16:48:
Now that it flashes, pull the coil wire out of the cap and hold it wit insulated pliers 1/4" away from the block. Crank it and see if there is spark there. If there is, the rotor in the Mag may be out of time, or the cap cracked or carbon tracked, or the rotor might be carbon tracked or the timing index broken in the rotor. The rotor shaft is gear driven from the mag main shaft, and must be timed with small inconspicuous marks so it points in the correct direction to fire when the points break. Look there before suspecting the coil. Jim
