Re: W-9 Magneto with 12 volt custom conversion is...
Posted by zim on March 20, 2014 at 17:08:37 from (69.89.182.98):
In Reply to: Re: W-9 Magneto with 12 volt custom conversion is... posted by Janicholson on March 19, 2014 at 18:43:17:
You were right. The coil is fine. Tonight, the test light didn't light up or flash at all. Later, it flashed briefly. The coil didn't produce visible spark, so I swapped out the one on my M. The M coil didn't spark either. The W-9 coil works on the M. The rotor and cap look good. Should I go ahead and get into the points? Will just cleaning and checking the gap mess up the timing? I really wish I had a distributor about now...
Thanks again
