Re: W-9 Magneto with 12 volt custom conversion is...
Posted by zim on March 22, 2014 at 13:19:10 from (69.89.182.98):
In Reply to: W-9 Magneto with 12 volt custom conversion is... posted by zim on March 18, 2014 at 19:12:18:
I filed and cleaned the points and it now fires! It'll run a little while when I dribble a little gas in the carb, but doesn't want to run from the carb and temporary fuel tank. Gas does run out the bottom of the carb when I pull the drain plug. I can rattle the float when I push it with a plastic tube through the drain hole. I'll be taking the carb off for a cleaning next.
