Posted by F4RM@11 on March 26, 2014 at 06:49:15 from (81.89.96.88):
I'm replacing a failed oil pressure gauge with a non-reproduction style gauge on a '53 SM. The old gauge is original with a threaded female fitting. The new gauge has a threaded male fitting that's not removable.
Will I be able to find an adapter in a plumbing supply store that allows me to connect the oil line with original fitting to the new gauge? Or is my best bet to cut the old supply line fitting off and add a new one?
I have the new gauge with me, but the old gauge is on the tractor (90 miles away), so I'm not sure of the fitting size on the supply line.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
