Re: Adapter for Replacement Oil Gauge
Posted by El Toro on March 26, 2014 at 17:05:46 from (96.244.7.206):
In Reply to: Adapter for Replacement Oil Gauge posted by F4RM@11 on March 26, 2014 at 06:49:15:
Since Rusty stated they have used steel tubing using a compression nut you need to remove the old oil pressure gauge. Then your local parts store can give you the correct fitting for your new gauge. I would pull the rotor so no one can start the tractor. Make sure you don't lose or misplace it. Hal
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
