656 gear problem. Help!
Posted by Zach Scherf on March 28, 2014 at 16:48:15 from (166.147.104.149):
I have a 656 that I did a clutch and ta job. First time digging into something like that on an ih. Got the whole thing together and dealer came and set clutch for me today since I got a lot of parts from them. The problem is the gear shifter slides like no problem. It used to be clear when I would move it into and out of gear. Now it slides so easy that you almost can't tell. I have all the pins in the thing. Never took the top apart just the bottom of the linkage where it goes into the shifter rods ps it a gear drive. Any ideas?? I pray I didn't screw something up and it needs to come apart again!! It is acting like its stuck in between gears and only slides easy on some gears others it acts like it won't go into gear
