Re: F-20 clutch shaft bearing
Posted by Mark in Upstate on March 30, 2014 at 14:51:08 from (174.236.1.180):
In Reply to: Re: F-20 clutch shaft bearing posted by Curt W. on March 28, 2014 at 14:34:40:
Fill the space behind the bearing with grease, through the bearing hole. Get all air out by forcing it out with more grease. Use a bolt with tight tolerance in the bearing hole. Keep adding grease and tapping bolt. The bearing will come out.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
