Re: F-20 clutch shaft bearing
Posted by 36F30 on March 30, 2014 at 16:10:20 from (174.30.79.209):
In Reply to: F-20 clutch shaft bearing posted by Mark in Upstate on March 30, 2014 at 14:51:08:
Mark in Upstate said: (quoted from post at 14:51:08 03/30/14) Fill the space behind the bearing with grease, through the bearing hole. Get all air out by forcing it out with more grease. Use a bolt with tight tolerance in the bearing hole. Keep adding grease and tapping bolt. The bearing will come out.
I'll try explaining this again....
If you look behind the pilot bearing on a F20 crank, there is a rather large hole center drilled in the crank, it goes all the way through into the crankcase. There is a felt wick in this hole that brings oil from inside the crankcase to oil the pilot bearing, which is sealed on just the outside. That felt just swells up and stays in there. Nothing holds it. There is no way your method will work on a F series engine, all the pressure your trying to build will just force the wick into the crankcase and Curt will end up with a huge mess inside his engine and still need an internal puller. While it may be a great technique for other engines it does not apply here.
I am adding a pic of a F30 pilot bearing/ rear seal, I have the wick removed and if you look through the bearing you can see half of the oil hole,its big. You can also see the original bearing that is sealed on the outside and open on the inside.
third party image
This post was edited by 36F30 at 16:28:06 03/30/14 2 times.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
