Re: B414 International
Posted by jdemaris on March 30, 2014 at 17:57:34 from (70.194.2.143):
In Reply to: B414 International posted by JPM in WA on March 30, 2014 at 15:28:05:
I think they are great tractors and often under-rated. Great parts accessibility too. They were basically remade new with different sheet metal a few years ago by Mahindra. So parts for your B-414 are available new from Case-IH, new from Mahindra, new aftermarket, etc.
The stuck PTO clutch is very common. It's a typical two-stage clutch but they seem prone to sticking in the British B-275s and B-414s. I've got four of the same basic tractors and two are stuck right now. One - I took apart - found nothing visibly wrong. No stuck disk either. Put it all back together and it worked fine for a month and then got stuck again. I never bothered to work on it further. It works fine. Just have to idle the engine down to almost "off" and then engage. Still works fine as a live PTO. Whatever causes it - it is NOT a stuck disc in mine and not an adjustment. Even stuck - it works much nicer then my Ford 641 or Case VAC with the non-live PTO.
Only flaw is with the diesels and their awful 1 volt glow plug system with the plugs all in series. Change it to 12 volt plugs in parallel and works MUCH better.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
