B414 International
Posted by JPM in WA on March 30, 2014 at 15:28:05 from (71.35.105.29):
I am considering buying a 1961 B414 International tractor. Does anyone have any feedback for me about this model? Any design flaws I should know about? I noticed that the PTO can only shift to off when the tractor is turned off and the same thing happens to engage the PTO, the tractor must be off. I wonder if this is normal operation or not? Any help would be appreciated.
Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
