Re: 5288 low range
Posted by Allan In NE on March 31, 2014 at 08:37:46 from (199.47.66.57):
In Reply to: 5288 low range posted by Brian Stortenbecker on March 30, 2014 at 21:31:14:
That set-screw holding the fork had an issue with working loose. Usually ended up with it not going into reverse tho.
I"d sure check that first; especially so, if the sentry light isn"t coming on.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
