5288 low range
Posted by Brian Stortenbecker on March 30, 2014 at 21:31:14 from (69.80.125.18):
5288, low range does not work. High, med and reverse work fine. When it's put in low there is no grinding, does not move, nothing. Linkage checks out okay. I know I can look at the reverse, low shift fork and find out more. Just looking for opinions.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
