Re: 5288 low range
Posted by Brian Stortenbecker on March 31, 2014 at 17:17:17 from (69.80.125.18):
In Reply to: 5288 low range posted by Brian Stortenbecker on March 30, 2014 at 21:31:14:
Maybe a bit of confusion. I'm talking low range, which should be behind the master clutch, the speed trans works great.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
